7 members (MRMEROTH11, FAST55, Otto Skorzeny, Hotrod Lincoln, carbking, TUTS 59, Joe H), 86 guests, and 1 robot.
Topics128,051
Posts1,055,768
Junior Member
Junior Member
Hi; I have a sort of general question. Can I replace crank shaft main bearings (bushings) without pulling the engine? With the crank in place? If so, how do I get the bearing half out from between the crank and the block? Is there a tool for this? Sad to say, this is my son's F#&d V-6 in his van and it's really hard to get the engine out. I hate working on F#&ds.
Any advice would be appreciated.
Rich
3B Offline
Hy Rich,the short answer is yes. There may be a specific tool available, but most of the time you just make a tool out of a cotter pin, slip it into the crankshaft oil hole and form the legs to lay flat on the crank to help you turn the upper bearing shell out of the block, you can only turn it one way so the locating tang comes out first. You will have to loosen all the main bearing bolts quite a bit before trying this, hope this helps. I don't own a Fix Or Repair Daily just because I don't mind fixing them once but then I want to drive it a few hundred thousand miles before fixing it again.
3B,
I'm not sure where you came from, but every one of your posts amaze me. You are a "tinkerer
extraordinaire"...always great info and ideas! smile
Stuart
3B Offline
Hy Stuart, thanks for the kind words, I'm just trying to do my part to help out where I can.
The cotterkey idea is something I have never used, but I think it is a very good idea. In the past I have just used a small screwdriver and pushed the bearing as far as I could, then grabbed it with a pliers on the opposite side and pulled it the rest of the way out.
I also do not like working on F**ds. I think they make good enough products but they are very hard to work on, much harder than GM or Chrysler.
Junior Member
Junior Member
Hi Guys;
Great ideas. Very much appreciated. Thanks 3B - pretty slick. I'll have at it. You guys are great.
Rich
Riding in the Passing Lane
If it was a stovebolt it would be a piece of cake but on a ford van pulling the pan with the engine in quite a chore. Than you won,t have much room to work.
1972 Chevy c10 Cheyenne Super
