2 members (Hotrod Lincoln, Jimmie D), 55 guests, and 3 robots.
Topics128,211
Posts1,057,475
Members48,473
#548698 06/22/2009 2:52 AM
I bought a 58 235 engine. I took it apart today, it turns over by hand easily, I adjusted the rockers and cleaned the oil pump screen. I found some sludge in the oil pan, and it sticks to a magnet. The engine did not have an oil filter. What would the sludge be from? Just improper oil changes? Were the bearings back then made out of ferrous material? The guy I bought it from had got it with a truck he bought. So he didnt know anything about it. Should I just clean it up and run it? Im trying not to stick alot of money into it.
Well, if you have the pan off, I would have a look at the bearings and check their clearance. It would be good to know if they are OK or not before installing the motor.
1951 1 Ton Completed
At a minimum i would clean out the pan real good and put on a new oil pump if you can find one. Start it up and drive it.
"Drugs are money, money is power, power is security." - Kent Heiner
Nedrow population 2212
Carbon footprint family of 2/11 tonnes of CO2/yr
BITOG: What causes sludge?
I would use a 10W-30 HDEO (Heavy Duty Engine Oil) like Shell Rotella T4 (CL-4/SN) in your engine. The detergents in HDEO will slowly clean up the deposits in your engine. Brad Penn makes a 10W-30 HDEO (CI-4/SL) too.
Engine Oil Article
Sludge Article
