1 members (baldeagle),
89
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 44 New Guy | | New Guy Joined: Dec 2007 Posts: 44 | Have a 54 dually purchased couple years ago was wondering where I could find out how many were produced, only seen two on ebay , the one I bought and another which was listed at the same time, haven't seen another since beginning to think they may be a rare breed. Was going to request a restoration pack from GM , but with all the problems there not sure thats possible now. Thanks for any info. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | '54 3/4-ton dually would be real rare because its not listed as a factory option.
'54 1-ton dually is not so rare. I own one and I'm aware of others.
Are you sure its a 3/4-ton and not a 1-ton? What is the wheel base and serial number?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | | | | | | Joined: Dec 2007 Posts: 44 New Guy | | New Guy Joined: Dec 2007 Posts: 44 | sorry took so long to answer back had to go make a dollar, Mines a 3/4 3600, J54, 125 inch wheel base, made in kansas city, has 16 inch split rims. The dually's are listed on page 94 of the owners manual, in the load capacity chart. Think I may of seen one 55 first series 3/4 ton on ebay once. I have seen a lot of 1 tons just only the two 3/4 tons. It was proably delivered as a cab and chassis type as it has a small grain bed on it, as did the other truck that I seen on ebay. Mine may have been used as a fire truck of sorts once as original color was red, then was painted kind of a school bus yellow like maybe a county truck, then now is blue. Bought it from a lady who said it was her grandfathers but she wasn't certain if he bought it new. anyways just was woundering if there were any records as to how many may be out there. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Well I guess I stand correctecd. I just went through the '54 restoration pack and sure enough duals are listed as an option on a 3/4-ton. I was sure they didn't offer that until the Task Force years. The restoration pack is available online. '54 Chevy Restoration Pack. The wheels listed are 16 inch, which is different than the 18 inch wheels on a 1-ton dually. Do you have pictures or yours posted online? Especially that show the wheels? Do they look like the 1-ton wheels?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Dec 2007 Posts: 44 New Guy | | New Guy Joined: Dec 2007 Posts: 44 | No don't have any pic's on line was planning to submit one as seen their aren't any posted on stovebolt, but don't have a picture of the truck by itself, always another old piece of iron in the picture, so thought I'd try to get a good picture. the wheels are more like what you would see on late model trucks, only four holes in the wheel for valve stem alignment. thanks for the info on restoration pack | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | My '54 has a dual wheel adapter from the standard hub centered 8 lug pattern to a stud centered 6 lug pattern. I have also seen an 8 lug to 5 lug dual wheel adapter. | | | | | Joined: Dec 2007 Posts: 44 New Guy | | New Guy Joined: Dec 2007 Posts: 44 | The front hubs on my truck are different than the regular 3/4 ton pickup, they are similar to a 1 ton so all wheels are inter-changable. there are no adapters,front or rear, thanks for the input. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Are you running tube type tires? Are they the original wheels?
I assume you have 12 inch rear brakes, else the 16 inch wheels would likely be a problem. There does not appear to be a larger brake option on the 3/4-ton.
The 1-ton has 14 inch brake drums which requires the 17 inch wheels on a single wheel truck and 18 on the dual wheel trucks.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Dec 2007 Posts: 44 New Guy | | New Guy Joined: Dec 2007 Posts: 44 | As far as I know they are the orginal wheels, looked at pics of the other 54 I had seen on ebay and the wheels are the same for both trucks, not sure what the brake drum size is , the brakes were up when I got the truck so have done pretty much nothing but drive it. The tires are tube type. Wanted to repack the front wheel bearings but anm not sure if the bearing dust caps screw on and off or if you just pry them off. They are not rounded like on a 1/2 ton truck, the dust caps are 6 or 8 sided as if possibly a wrench is suppose to be used. Didn't want to ruin a cap as would be hard pressed to find another. | | |
