1 members (Ponchogl),
142
Mod | | | Forums66 Topics128,152 Posts1,057,011 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 61 | My front axle was from the beginning a little bended.
As far as I know, axles are usually made of high-alloyed steel and therefore I was very worried about the necessary truing. A local hardening shop made an spectral analysis and the results are a little surprisingly for me.
The axle is made of a "better mild or structural steel" with less than 0,3 % carbon (C). I was surprised but the clerk not. High-alloyed steel would have been very unusual for the 1950s, that material came up within the last 30 years.
Conclusion: The material is not very brittle and I can truing it.
If anybody needs the complete analysis, contact me.
'59 Apache '67 Mustang
| | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | cool to know. i have cut up a lot of front axles and they don't always seem that hard. i guess they need to take the stresses of use with out stress fracturing. rear inner axles that wear are usually harder than the i beam front ones. sounds like you spent some cash, consider just doing the grinding spark test? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Wow, there is some sophisticated technology being applied here. This is indeed a very interesting posting. | | | | | Joined: Feb 2004 Posts: 29,869 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,869 | The results aren't surprising to me at all, since I grew up around a shop where we bent axles all the time, doing front end alignments. They are forged, and extremely tough, but not brittle. It's really surprising how far an axle has to be flexed to get a degree or two of alignment angle change. It rebounds at least halfway after a bending procedure, so to move a point on the axle 1/4" for instance, it must be flexed 1/2" or more, and allowed to rebound partway. Jerry
