| | | Forums66 Topics128,037 Posts1,055,463 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#54817 01/11/2006 10:29 PM | Joined: Oct 2005 Posts: 41 New Guy | | New Guy Joined: Oct 2005 Posts: 41 | Can anyone tell me the size of carriage bolts used in the front motor mount for a 46?
You never have enough, til you have too many!
#54818 01/11/2006 10:39 PM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 7/16" hold the mount to the engine, 3/8" hold mount to the crossmember.
See the USA in your vintage Chevrolet! My Blog | | |
#54819 01/11/2006 10:48 PM | Joined: Apr 2005 Posts: 261 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 261 | The front engine mount carriage bolts were 3/8 - 24 x 2" p/n 3652729
34 & 35 trucks are the greatest
#54820 01/11/2006 11:53 PM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The "3/8 - 24 x 2" p/n 3652729" holds the mount to the crossmember. The 7/16" bolts that hold the mount to the timing plate were spot welded in place so the parts book does not give them a part number.
#54821 01/12/2006 3:51 AM | Joined: Oct 2005 Posts: 41 New Guy | | New Guy Joined: Oct 2005 Posts: 41 | Thanks, I just picked up the old style plate and the square holes are rounded out. I'm going to weld and repair them so I needed the correct bolts to fit them.
