0 members (),
67
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 256 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 256 | I've been messing with it for three days now and am getting nowhere. I'm trying to drop the crank but the dang oil pump won't come out. I can barely even get a wrench up to the bolt and even when I can it just rounds it when I try to turn it. I tried vise grips, and even that couldn't get it out. I even tried heating it some and nothing.
Is there some trick I'm missing? I'm at wits end with this thing.
Engine is a '53 216. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Just checking but did you loosen the lock nut first?
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2009 Posts: 256 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 256 | *insert obscenities*
Lock nut??????????
WHAT!?!?!?!?
I only saw a bolt threading into the pump, is there a nut butting up against the pump?
| | | | | Joined: Oct 2006 Posts: 9 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9 | Take 5/8 wrench, break loose the hold nut...run it down the bolt. It will bottom out, then break loose the bolt from oil pump retainer. It's real fun when engine is stuck. I going do two GMC 302s that are locked up today.
Buy,Sale,Trade inline Chevy/GMC engines and parts. International shipper, custom crate builder, 74% freight discount 48 state. James~503-740-6783 http://www.JJinlines.com | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you have ever wondered where the expression "busted knuckles" came from, this particular job will be helpful in clearing that up! Get the best 5/8 wrench that you have for this job. What you don't want is rounded edges on the nut! | | |
