3 members (KEVINSKI, Cletus1950, Bill Hanlon), 127 guests, and 1 robot.
Topics128,175
Posts1,057,055
Members48,460
Is there a short-shaft water pump kit out there for the 230/250 sixes to make a better fit when dropping into an '47-'54 or earlier truck ?
If so, what sort of results has anyone had with them ?
(Just mulling over some options to build a daily driver out of the parts on hand...)
Thanks !
Frank McMullen
Frank McMullen
1941 Chevy dump truck
1949 GMC 100 pick-up
1954 Chevy 3600 pick-up
1955.1 4400 dump truck
1941 De Soto & other MoPars
1928 Model A F**D Special Coupe
I put a 292 in my 59 and I could use the stock fan with a 1" spacer. The 292 is the taller version of those motors. I do have a 1 ton though, but it uses the same sheet metal as the rest of the range.
