0 members (),
128
Mod | | | Forums66 Topics128,167 Posts1,057,021 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#54815 01/11/2006 3:41 PM | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | Is there a short-shaft water pump kit out there for the 230/250 sixes to make a better fit when dropping into an '47-'54 or earlier truck ?
If so, what sort of results has anyone had with them ?
(Just mulling over some options to build a daily driver out of the parts on hand...)
Thanks !
Frank McMullen
Frank McMullen 1941 Chevy dump truck 1949 GMC 100 pick-up 1954 Chevy 3600 pick-up 1955.1 4400 dump truck 1941 De Soto & other MoPars 1928 Model A F**D Special Coupe
#54816 01/12/2006 5:42 AM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | I put a 292 in my 59 and I could use the stock fan with a 1" spacer. The 292 is the taller version of those motors. I do have a 1 ton though, but it uses the same sheet metal as the rest of the range. | | |
