0 members (), 93 guests, and 1 robot.
Topics128,055
Posts1,055,782
#548114 06/20/2009 1:49 AM
I've been messing with it for three days now and am getting nowhere. I'm trying to drop the crank but the dang oil pump won't come out. I can barely even get a wrench up to the bolt and even when I can it just rounds it when I try to turn it. I tried vise grips, and even that couldn't get it out. I even tried heating it some and nothing.
Is there some trick I'm missing? I'm at wits end with this thing.
Engine is a '53 216.
Just checking but did you loosen the lock nut first?
My Blog
*insert obscenities*
Lock nut??????????
WHAT!?!?!?!?
I only saw a bolt threading into the pump, is there a nut butting up against the pump?
There is a lock nut that takes a 5/8" wrench, 1/2" on the bolt.
This link shows the bolt and nut,#1.672.
http://chevy.oldcarmanualproject.com/parts/1929_41/41cp032.html
My Blog
1 Offline
Take 5/8 wrench, break loose the hold nut...run it down the bolt. It will bottom out, then break loose the bolt from oil pump retainer. It's real fun when engine is stuck. I going do two GMC 302s that are locked up today.
Buy,Sale,Trade inline Chevy/GMC engines and parts. International shipper, custom crate builder, 74% freight discount 48 state. James~503-740-6783
http://www.JJinlines.com
If you have ever wondered where the expression "busted knuckles" came from, this particular job will be helpful in clearing that up! Get the best 5/8 wrench that you have for this job. What you don't want is rounded edges on the nut!
1951 1 Ton Completed
