| | | Forums66 Topics128,105 Posts1,056,205 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 46 New Guy | | New Guy Joined: Apr 2006 Posts: 46 | Good Afternoon, I lost (or misplaced) my only key for my truck. I could use some info on how to hot wire it so I can at least move from the garage to the street.
Thanks in advance, Craig
1953 GMC half-ton
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Still 6 volts and a stomp starter?
If so, just run a jumper from the "hot" post of the starter to the coil (the side that doesn't connect to the distributor). The stomper works without the key, should be good to go. | | |
