9 members (Phak1, Bill Hanlon, Rusty Rod, TUTS 59, Napco Man, Cosmo, ndkid275, 2 invisible), 57 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#548074 06/19/2009 10:53 PM
Good Afternoon,
I lost (or misplaced) my only key for my truck. I could use some info on how to hot wire it so I can at least move from the garage to the street.
Thanks in advance,
Craig
1953 GMC half-ton
GMC53 #548078 06/19/2009 11:00 PM
Still 6 volts and a stomp starter?
If so, just run a jumper from the "hot" post of the starter to the coil (the side that doesn't connect to the distributor). The stomper works without the key, should be good to go.
