1 members (Rusty Rod), 80 guests, and 2 robots.
Topics128,127
Posts1,056,680
Members48,452
Apprentice
Apprentice
The choke on my 59 apache is sticking. Started her no problem, but after running for a few minutes, fuel started leaking out of the back / underside of the carb...removed carb & dumped excess gas (the carb was completely flooded), but when I reattached it, I realized the valve (that closes when you pull the choke) is sticking... Is it carb rebuild time, or carb cleaner time? Any ideas? Do you think the choke cable is just bound up and a new one would potentially help solve the problem? Any input would be greatly appreciated.
To be on the safe side, a squirt of WD-40 or something as such into the choke cable's ends, and some Carb Cleaner on the choke, then open/close it a few times. It helped quite a bit when I took my carb off ...
1959 Chevrolet 3100 Stepside Apache
"Ignorance is bliss. Here's a history book."
Apprentice
Apprentice
Sounds like a good place to start - I'll give it a shot and let you know how it goes - thanks RI-59. I'm wondering how easy it is to replace the whole choke cable...I saw a brand new one for 12 bucks...seems like it cant be that big of a deal...
