0 members (),
107
Mod | | | Forums66 Topics128,265 Posts1,058,365 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 85 | Right now my doors are in really nice shape with only rust holes at the seal on the bottom.I know the best way to slow the rust down would be to get the whole truck out of the weather,but for now I just want to keep up with it and not let it get out of hand. Would it be a good idea to clean them out good and then POR-15 the inside of the door?I only started useing this stuff in the last few months and I liked how it works,but I'm not sure how well it would work here. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | clean as good as you can mechanically and then use a good rust converter [POR makes one] - any top coat inside there will just make future repairs harder
Bill | | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | Keep in mind that most rust issues in enclosed panels such as doors occur when water can't drain out. Make sure your weep holes are open now AND after you put anything into the door.
