8 members (SNOYL, Southerntruck, Phoneman, wilbur53, 1955 1 Series, SmalltownTRKGuy, Jon G, ShopRag), 155 guests, and 4 robots.
Topics128,209
Posts1,057,461
Members48,471
Hi, no I am not looking to make this truck slammed to the ground. its a 56 3/4 but it has one ton springs (I have around 6-8 inches of leaves, w a curled up one pointing the other direction)so the back is at least 4 inches higher than the front, so with no load, it sticks up in the back, prettyt dramatically. is it possible to remove some leafs, or do something to drop the back some? I jsut want the truck to appear more level. thanks for any help you can supply.
56 stepside 3/4 ton longbed
This probably belongs in the Hi-po shop forum but to answer your question, yes, it is possible to remove some leaves. I've done it on my 1/2 ton and there's lots of others that have done this on their trucks too. Skip on in to the Hi-po forum, there's several threads on this.
remove post please
