8 members (Scott, klhansen, Rusty Heaps, Tronman, Jon G, Hotrod Lincoln, 2 invisible),
71
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,206 Posts1,057,433 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2002 Posts: 159 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 159 | Hi, no I am not looking to make this truck slammed to the ground. its a 56 3/4 but it has one ton springs (I have around 6-8 inches of leaves, w a curled up one pointing the other direction)so the back is at least 4 inches higher than the front, so with no load, it sticks up in the back, prettyt dramatically. is it possible to remove some leafs, or do something to drop the back some? I jsut want the truck to appear more level. thanks for any help you can supply.
56 stepside 3/4 ton longbed
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | This probably belongs in the Hi-po shop forum but to answer your question, yes, it is possible to remove some leaves. I've done it on my 1/2 ton and there's lots of others that have done this on their trucks too. Skip on in to the Hi-po forum, there's several threads on this. | | | | | Joined: Sep 2002 Posts: 159 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 159 |
