3 members (Steelonsteel, Hotrod Lincoln, UtahYork), 72 guests, and 3 robots.
Topics128,261
Posts1,058,341
Members48,485
Chevs of the 40’s has a waffle pattern Felt Body Deadener that is used on the toe boards and roof of the original AD’s. What was used to glue or stick this to the panel?
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
3M makes a spray adhesive. You could also use a contact adhesive.
Bruce
My Trucks
Stuff I Collect
I beleive the original was some sort of asphalt based adhesive (I could be wrong on that). Like Bruce said, 3M makes a very good spray adhesive, 3M Super 77. Should be able to get it at the flaps (Napa carries it) or body shop supply.
Bill Burmeister
Being that it's an asphalt based material to begin with I think there might be a problem with the 3M 77. I'm thinking more along the lines of an asphalt based calking/adhesive in the tube. DAP makes one that might work well.
DG
Denny G
Sandwich, IL
Denny,
When I did mine, I just used 3M undercoating. From what I could tell, the original stuff had the appearance of undercoating. It worked OK, but I had to keep the felt taped up for quite a while before the undercoating set enough to hold. 3M makes a product called body schutz that I would investigate also.
Appearance is not that important on the roof, but I wanted that black "tar" showing through the unused stamped holes in the toeboards.
Bob
Thanks Bob, I know just what you mean, I'll have to look into that. Found this and it is black.
http://www.amazon.com/3M-Schutz-Rub...automotive&qid=1245346932&sr=8-1
Did you use the same weight in the roof as you did on the floor and did you use a piece in the door? I know it wasn't originally in the doors but I do see it behind the headliner, which I still have in place.
Denny G.
Denny G
Sandwich, IL
Moderated by  ndkid275, Phak1
