1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
I hate to do something that would seem ... rather stupid, but here goes: As the post title indicates, I have an interesting starter. This is on a '54 GMC, I understand that it is bad to hook 12V up to it, but I did just for a second to see if the starter motor was fried, and the little sucker just started whirring without any key or push-starter behind it -- Has the 12V battery fried something, or am I missing some cutoff wire here?
1959 Chevrolet 3100 Stepside Apache
"Ignorance is bliss. Here's a history book."
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
Sounds like the solenoid is stuck. Unless you have tried to start your truck & had the starter engage for a long period of time 12volts won't hurt it. Lots of us have done it w/out any problems. Heck I ran a 6volt starter on my VW for over 10yrs w/out problems....Joe
Is your 1954 GMC still a 6v positive ground electrical system?
Where did you make the 12v connections to your truck?
Yeah, it's still a 6V Positive, forgot to mention that. I made the connections right up where the old battery was (I made sure to put Pos. to Pos. and Neg. to Neg.). Thanks for the idea, Zookeeper, I'll see when I next look it over if that's it. EDIT: Forgot to mention, when I hook up the 12V battery, nothing else works: No lights, no gauges, Just the lonely starter trying to spin up.
