| | | Forums66 Topics128,175 Posts1,057,054 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Chevs of the 40’s has a waffle pattern Felt Body Deadener that is used on the toe boards and roof of the original AD’s. What was used to glue or stick this to the panel? Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | 3M makes a spray adhesive. You could also use a contact adhesive.
Bruce | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I beleive the original was some sort of asphalt based adhesive (I could be wrong on that). Like Bruce said, 3M makes a very good spray adhesive, 3M Super 77. Should be able to get it at the flaps (Napa carries it) or body shop supply.
Bill Burmeister | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Being that it's an asphalt based material to begin with I think there might be a problem with the 3M 77. I'm thinking more along the lines of an asphalt based calking/adhesive in the tube. DAP makes one that might work well. DG
| | | | | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | Denny, When I did mine, I just used 3M undercoating. From what I could tell, the original stuff had the appearance of undercoating. It worked OK, but I had to keep the felt taped up for quite a while before the undercoating set enough to hold. 3M makes a product called body schutz that I would investigate also. Appearance is not that important on the roof, but I wanted that black "tar" showing through the unused stamped holes in the toeboards.
Bob | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Thanks Bob, I know just what you mean, I'll have to look into that. Found this and it is black. http://www.amazon.com/3M-Schutz-Rub...automotive&qid=1245346932&sr=8-1Did you use the same weight in the roof as you did on the floor and did you use a piece in the door? I know it wasn't originally in the doors but I do see it behind the headliner, which I still have in place. Denny G.
