0 members (),
148
0
Mod | | | Forums66 Topics128,101 Posts1,056,182 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 791 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 791 | Any help with a horn installation on 1948 Chevy 1/2 ton truck is appreciated--6 volt system. How many horns, type, where placed, and wiring detail needed. Thanks-- HONK-HONK! | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The original had one horn mounted on the intake manifold wired direct. You can use any 6 volt horn or horns & mount them on the inner fenders, frame rails, or core support. I would use a relay in the system. Run the hot wire to the bat term of the relay. Run a wire from the horn/s to the horn term. Run a wire from the steering column to the button or switch term. Use 12 gauge wire on the hot lead & to the horn/s. The button wire can be small gauge, 16-18. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2009 Posts: 791 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 791 | Thanks for the info. Are there any pictures or diagrams available as well? What would the original horn have looked like? I have seen the coiled-type horns, as well as the cone-shaped horns; did it matter which one was used? I will take all the advice that I can get--much appreciated. BEEP-BEEP | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | The original was probably one of those big, cone shaped ones. But if you're not concerned about originality, then, as was mentioned, any 6 volt horn will work. | | |
