8 members (55shaker, Wheelie, Gdads51, baldeagle, Otto Skorzeny, ShopRag, 78buckshot, 1 invisible),
108
Mod | | | Forums66 Topics128,268 Posts1,058,384 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 54 | Removed and checked the radiator with low pressure air under water, there are two leaks at bottom seam at fins (May not all be at surface?) Is there a good way to solder or a type of liquid weld to fill? Anyone do this repair??
Eric | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Best bet would be to take it to a radiator shop.
Bill Burmeister | | | | | Joined: Mar 2009 Posts: 124 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 124 | i believe they can be silver brazed.
never done it though. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Not silver brazed... soft soldered! Big difference. Stuart | | | | | Joined: Apr 2005 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 54 | Soft solder, will have to look that up. It must melt at lower temp than the regular solder? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | use 50-50 acid flux solder on radiators, but if you have tubes leaking at the tank joint it needs to be redone properly or you'll be patching it the rest of yer life .... take it to a shop, they'll redo both tanks properly
Bill | | |
