4 members (dt235sd, Rick Brown, Jon G, 2-Ton), 170 guests, and 2 robots.
Topics128,108
Posts1,056,238
Members48,437
#547322 06/17/2009 1:07 AM
I just purchased LMC's 2-1/2 drop spindles and 4 inch drop rear springs for my 61 Apache and was wondering if anyone else has done the same on these trucks. Feedback of any kind would be greatly appreciated.
Thanks. laalaa
1961 Chevy C10 Stepside
On my web site
Have you swapped out your front end so the drop spindles will work? You have a trsion bar set up in the front of your truck and those spindles are for the 63-66 trucks. Maybe I am wrong...do they make a spindle for the 61? If so then I need to buy that kit too smile
I may be wrong and I apologize if I am. Someone wlse will sound off with the real knowledge!!
Kyle
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
I have a 60 C10 that have the 2" drop spindles installed. I bought the truck that way, but I'm sure I've seen them in the catalogs for 60-62.
Joe
54 Triumph TR2(rhd)needs total resto.
60 Apache 10 stepside shortbed
99 Excelsior Henderson
Fort Knox, Yes they do have 2 1/2 inch drop spindles for 60-62 and 63-66 from LMC.
http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=67
On my web site
LMC used to get their drop springs from CPP, Classic Performance Products. If you buy directly from CPP it will save you some hard earned cash.
4" Drop Rear Coil Springs
LMC = $169.95 CPP = $95.00
And it looks like the drop spindles are also cheaper from CPP...
Drop Spindles
LMC = $299.95 CPP = $239.00
A savings of $136!
You might want to send those parts back, order the parts from CPP, and put the savings in your pocket.
Here is CPP's website:
http://www.classicperform.com/
Hot Rod John,
I just bought the drop spindles and springs from LMC. I could not find the 4 inch drop springs for 60-62 though CPP. Do they sell them???
On my web site
Yep, well at least they show them online.
Here is the link:
http://www.classicperform.com/6092chevtrk.htm#Spindles%20&%20Coil%20Springs
RCS6034 1960-72 rear 4" drop, pair $95.00
CP4S1 1960-62, 2-1/2" drop, set $239.00
Thanks Hot Rod John. I will compare prices next time. Much appreciated.
On my web site
