7 members (DadsFirstPickup, 51sub, asilverblazer, Youngin' Tut 59, Otto Skorzeny, amtrakjoe, moparguy), 69 guests, and 2 robots.
Topics128,180
Posts1,057,146
Members48,463
#54730 01/09/2006 11:04 PM
TT
Offline
Who can tell me the following specs. for shopping at NAPA. This is to fit my oil and temp guages back to my 235:
1. Oil tube
2. Temp Line
Appreciate it. TIA.
1951 1/2 ton "Buck"
Recently lobotomized for your safety.
Riding in the Passing Lane
The oil line comes in a kit with plastic tubing or you can get copper tube & fittings. The temp is a one piece deal the tube is part of the gauge. If it is cut or broken the whole unit will have to be replace or rebuilt.
1972 Chevy c10 Cheyenne Super
TT
Offline
Thanks WB however I have the lines for both temp and oil...what I lack are the end fittings.
1951 1/2 ton "Buck"
You can probably get the oil line fitting at Napa. The temp is a special fitting. Some of the Bolters probably have one on an old engine. I,m going to canabolize ? one this saturday. I,ll see if it has the fittings on it.
It doesn,t. Sorry.
TT, my understanding is that the chevys (235) have an electronic temp sender while the GMC's have a capillary one. The capillary version must be replaced with the gauge (I still have to do this) but I imagine that an electronic one can just run a new wire to the sender. I would appreciate any further input here since I have to mate the capillary (GMC) gauge with my chevy engine.
