6 members (Gdads51, 3B, 32Fordpuchoptop, Bill Hanlon, Otto Skorzeny, Joe H), 166 guests, and 2 robots.
Topics128,110
Posts1,056,246
Members48,437
#547231 06/16/2009 7:19 PM
Hello. In the process of getting the last of the parts to start my switching to front disc and adding a dual power booster under the floor. I have the residual valves, but I am not sure how to make them attach to the new 3/16" brake line that I am using. It looks like one end has an adapter that the brake line will go into, but the other end of the valve has what looks like a fitting that wants a line to go through and then be flared.
Am I missing something? The local part store doe not have any type of adapter and I do not want to have cut a fitting off a new line and then take it somewhere to get the line flared. headscratch
An adaptor (3/8"-24IFF to 1/8" NPT male) screws in each end so you can screw in your standard (3/8'x24 threaded nuts) double-flared brake fitting.
I'd suggest you get a Speedway catalogue....great service and good pictures of all the common stuff you'll need to finish off your truck. Check out:
www.SpeedwayMotors.com
or call: 1-800-979-0122
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
also flaring tools aren't that expensive and most parts stores will lend/rent them.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
there are special nuts for that application. for a GM proportioning valve there are 3 different sizes and they are colour coded as to size.red,green and blue. You can use adaptors to compensate, but if your making new lines may as well do it properly
ron
