6 members (HandyAndy, dt235sd, Gdads51, Joe H, 3B, DennisM), 118 guests, and 0 robots.
Topics128,049
Posts1,055,693
#54720 01/09/2006 4:24 PM
Hi all, I'm restoring a 54 chevy and I'm looking for a rebuild kit for the 235. Thought I would go thru it since it is out of the truck and before I paint it. The truck will become a daily driver.
#54721 01/09/2006 7:36 PM
morepower16
Any of the vendors will be good but one comes to mind right away
http://www.kanter.com wink
The overhaul gasket set is 75.00 but is included in the basic overhaul kit550.00/the master kit835.00/or the deluxe ohaul kit1115.00
Regards
#54722 01/09/2006 8:59 PM
Morepower16, try EGGE machine for your kit I think they may be a bit cheaper. www.egge.com
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
#54723 01/09/2006 9:27 PM
41chevy
Cheaper in some but more on other parts
Gasket set more
Cam more+ core charge
Rocker assemblies more + core charge etc.
Regards
#54724 01/09/2006 9:38 PM
manpower16,
Are you talking about just gaskets? The "hard" rebuild parts would be dependent on the condition of the engine and would probably be better supplied by the machine shop that was going to "rebuild" your 235. It's quite a leap from re-gasket to re-build!
Stuart
#54725 01/10/2006 1:01 AM
Thanks all, I'm going to do a basic overhaul as the engine is in great shape still. I'll give Kanter a shout for the basic kit.
