| | | Forums66 Topics128,052 Posts1,055,726 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#54720 01/09/2006 4:24 PM | Joined: Dec 2005 Posts: 45 New Guy | | New Guy Joined: Dec 2005 Posts: 45 | Hi all, I'm restoring a 54 chevy and I'm looking for a rebuild kit for the 235. Thought I would go thru it since it is out of the truck and before I paint it. The truck will become a daily driver. Thanks, | | |
#54721 01/09/2006 7:36 PM | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | morepower16 Any of the vendors will be good but one comes to mind right away http://www.kanter.com The overhaul gasket set is 75.00 but is included in the basic overhaul kit550.00/the master kit835.00/or the deluxe ohaul kit1115.00 Regards | | |
#54722 01/09/2006 8:59 PM | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | Morepower16, try EGGE machine for your kit I think they may be a bit cheaper. www.egge.com
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
#54723 01/09/2006 9:27 PM | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | 41chevy Cheaper in some but more on other parts Gasket set more Cam more+ core charge Rocker assemblies more + core charge etc. Regards | | |
#54724 01/09/2006 9:38 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | manpower16,
Are you talking about just gaskets? The "hard" rebuild parts would be dependent on the condition of the engine and would probably be better supplied by the machine shop that was going to "rebuild" your 235. It's quite a leap from re-gasket to re-build!
Stuart | | |
#54725 01/10/2006 1:01 AM | Joined: Dec 2005 Posts: 45 New Guy | | New Guy Joined: Dec 2005 Posts: 45 | Thanks all, I'm going to do a basic overhaul as the engine is in great shape still. I'll give Kanter a shout for the basic kit. | | |
