5 members (68ironhead, TUTS 59, Phak1, Jay R, Otto Skorzeny), 89 guests, and 3 robots.
Topics128,136
Posts1,056,428
Members48,441
#547155 06/16/2009 2:09 PM
I have a 59 chevy with a 235, a guy wants to sell me a 292. Would it be worth it, would it bolt up the same and could I still use my 3speed transmission. Any big issue's that i might come across, I'm new to all this stuff.
i don't know about the trans but the engine Mount's are different they are on the side instead of the front .you would have to build a set of Mount's and cross member .if you have the complete mounts from the truck that the 292 was in ,use 1/2x 3 flat stock to span the frame and set the original Mount's on it and bolt them on .worked good on my 61 gmc .
The 292 would be a super engine to go with, bolts up to modern gm tranys (same as V8) and bellhousings, has tons of torque, lots of accessory manifolds. I've been thinking about building one for my 53. And there is a great book on building these, "Chevrolet Inline Six-Cyliner, Power Manuel" by Leo Santucci. Also Check out Langdon's Stovebolt website for more info and www.inliners.org
1946 1/2-Ton Chevy
You will need to change out the bellhousing, as the bolt pattern is different. The 292 uses the same bellhousing as the V8. You'll need a bellhousing from a '55-'72 V8 or '63-'72 6 cylinder. The front mounts will have to added as well. There are kits available to mount a V8 on th side mounts to the frame (not the crossmember style) that could be adapted to this fitment. You should be able to use your existing trans just fine.
Bill Burmeister
Tom Langdon is in your general area and may be of help to you.
http://www.stoveboltengineco.com/
Drew
DrewP #547592 06/17/2009 10:03 PM
I believe '60-'62 truck bellhousings were set up for a hydraulic clutch. You may want to stay away from those years for your particular engine swap.
Steve
'49 3800
'52 3600
'57 3100
That is correct, exept for 4x4 models, which still used the mechanical clutch.
Bill Burmeister
