6 members (Gray_Ghost, VEW, FAST55, 50Chevy3100, J Lucas, 1 invisible), 70 guests, and 0 robots.
Topics128,075
Posts1,055,918
Members48,429
#547058 06/16/2009 3:19 AM
Hello Truckers, Thanks for the replys on my brake problems. Now, How do you check a power steering pump. I had to remount the one that came with this truck to correct a belt alignment problem and when I got it back together, It did not work. It had some assist to the right but no assist to the left and it does not make a groaning when turned to the stops. The pump was dry when I bought this truck. Do the steering gears have problems? Also it seems to leak a little bit at the top where the shaft comes in. Are seals availble and is it difficult to reseal?
If the pump was dry and now the front seal leaks and it doesn't seem to work you're probably due for a rebuilt pump. Usually they are reasonably priced.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
