1 members (delky),
130
Mod | | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#54713 01/09/2006 6:46 AM | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | Can some of you guys show me where you mounted your HEI external coils? I have mine mounted on the inner fender and I just think it sticks out like a sore thumb there. | | |
#54714 01/09/2006 3:33 PM | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Factory mounting was on the side of the engine. One of the side cover bolts was replace with a bolt that had a stud coming out of the head. That's where I'm going to mount mine on a aluminum plate. Sorry no pics. Larry
I don't own a vehicle that isn't old enough to drink. | | |
#54715 01/09/2006 7:39 PM | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | Two of the side cover bolts. The center two of the six bolts that hold the two side covers on. The front bolt of the rear cover and the rear bolt of the front cover. The regular bolts are a flanged bolt with a seal under the shoulder. These two bolts for the coil are the same with a threaded stud above the hex. A nut(2) holds the coil on and the hex part spaces the coil out from the covers. The internal coil type HEI has tree wires from the coil to the dist body. One of those wires is a ground wire for the coil, because as you can see, the cap would insulate it from ground. The external coil type HEI has only two wires from the coil to the dist, because the coil and the dist, share a common engine ground. If the coil is on the fender, you need to check and make sure you have a very good fender to engine ground.
'67 GMC 3/4 292 4spd
#54716 01/09/2006 7:46 PM | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | Hmmm. I see what you are saying Richard. That makes sense. I don't have the bolts\studs for the coil. Any idea where I could obtain those? | | |
#54717 01/09/2006 8:06 PM | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | Don't have a clue. I took the two that were on the engine I took the coil and dist off of. I would like to add that if the seals are leaking and they likely are, you can put a special washer on them. I found an aluminum washer with rubber molded to it on one side. They were at OSH(Orchard Supply Hardware) in the hardware bins where they keep odd fasteners, bushings, pins, etc.
#54718 01/09/2006 8:17 PM | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | LGriffin, I just reread what you wrote. a bolt that had a stud coming out of the head I missed the "head" part when I first read it. Sorry. There has to be a name for this type of fastener, but I'll be danged if I know what it is. Same as the main bearing bolt that supports the oil pickup tube.
#54719 01/10/2006 2:55 AM | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Richard, Great post! I should learn to get the parts out when I write or forget it. Ya there is probably a name for it, have to check with GM dealer. I worked in the defense industry and the library had a microfiche sorta thing with all the mil stds in it, neat, save my butt a few times. I just checked the Hillco catalog and they don't have it. Larry
