7 members (Cletus1950, Goach2, Wally / Montana, greenie-reddy, GRNHydra, Pete O, klhansen),
67
Mod | | | Forums66 Topics128,172 Posts1,057,038 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 12 New Guy | | New Guy Joined: May 2009 Posts: 12 | I need helping finding rear brake drums and parts for my 47 2spd rear. Does anyone sell parts for these axles? Is there a newer axle that has interchangeable parts maybe?
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy adfraser, could you give us the truck serial number? Is the axle an electric shift or vacuum shift? | | | | | Joined: May 2009 Posts: 12 New Guy | | New Guy Joined: May 2009 Posts: 12 | It's the vacuum shift model; when you ask for the serial number are you refering to the the number on the axle? The most visible is 128ONO. Here's my problem, a previous owner put a different drum on the drivers side. The drive flange has 8 bolts holding the flange to the drum, it looks like any modern day floating axle; the pass. side has the original 5 bolt cover thing. (that's a technical term "thing"). Furthermore the brake shoe adjusters on the drivers side are different from the pass. side. The drivers side not be visible except through the adjustment slots so tenderly cut out of the backing plate with an acetylene torch the the old adjustment nuts where. They both work fine ,but I don't like different. I don't care about them not being original I just want them to be and work the same. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy adfraser, I actually meant the serial number of the truck. Are we talking about a Chev or a GMC? Let me summarize you have an eight bolt axle on one side of the truck, and a five bolt axle on the other side, is that correct? | | | | | Joined: May 2009 Posts: 12 New Guy | | New Guy Joined: May 2009 Posts: 12 | The only legible part of the tag is 210W-I, you can sort of make out the 16,000 GVW. It's a Chevy, title say a 1947 and series 4STK, and yes on the axle summary, pass. side is a 5 bolt, driver is an 8. | | | | | Joined: May 2009 Posts: 12 New Guy | | New Guy Joined: May 2009 Posts: 12 | 21QW-I 2998 is the serial #. | | | | | Joined: Jul 2002 Posts: 165 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 165 | Check your E-mails, I sent you one. | | |
