The engine in my 66 c-60 was changed from a 366 to a 396. The person who did the job used a 366 water pump and blocked off the bypass hose on the water pump and then hooked a 3/4 hose in a big loop from the by pass port on the 396 manifold to a heater hose port on the 366 water pump. Does anyone make an adapter to join these together? This hose system looks like an accident waiting to happen.
