1 members (baldeagle),
89
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 86 'Bolter | | 'Bolter Joined: Aug 2004 Posts: 86 | mine is a '59 Viking 60 with 6 lug Budd wheels. I have seen a few Ford trucks from the mid '70's with 6 bolt 22.5 inch tubeless wheels. Will they fit?
Matt
"Brunhilde II" '59 Viking 60 To paraphrase Ben Franklin: "Big Bolts are proof that God loves us and wants us to be happy"
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Matthew Blair, yes I think they will fit, measure center to center of stud holes, and center hole dimension just to confirm, hope that helps. | | | | | Joined: Nov 2005 Posts: 116 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 116 | Matthew, I have a F600 that has 6 lug wheels measuring 7 5/8" CTC skipping one hole. The center hole is about 6 1/5". I've been looking for four good wheels/tires for the rear and found some decent tubeless 22.5s that came from UPS trucks. Seller says they will fit. He's wanting $100ea. Might be worth a try. | | |
