2 members (Nick in Manitou, 2-Ton), 333 guests, and 8 robots.
Topics128,159
Posts1,057,039
Members48,460
1 Offline
does anyone know if they make a serpentine belt for a 89' 4.3 without ac or ps.?
3B Offline
Hy 10 micron, the belt for "multiple accessories" but no AC is Dayco p/n 5060940, which is 94" long, 27/32" top width, 6 rib, if that is too long, give me an idea what length you think you need and i can look it up by size, hope that helps.
Most serpentine belt part numbers contain the belt's length in millimeters if you know how to read it properly. If you've eliminated some of the accessories, cut an old belt and wrap it around the pulleys to get an idea of how long the new belt needs to be. Don't forget to allow for the movement of the tensioner in your calculations, and make sure everything is going to turn in the correct direction.
