| | | Forums66 Topics128,163 Posts1,057,044 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | does anyone know if they make a serpentine belt for a 89' 4.3 without ac or ps.? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 10 micron, the belt for "multiple accessories" but no AC is Dayco p/n 5060940, which is 94" long, 27/32" top width, 6 rib, if that is too long, give me an idea what length you think you need and i can look it up by size, hope that helps. | | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | Most serpentine belt part numbers contain the belt's length in millimeters if you know how to read it properly. If you've eliminated some of the accessories, cut an old belt and wrap it around the pulleys to get an idea of how long the new belt needs to be. Don't forget to allow for the movement of the tensioner in your calculations, and make sure everything is going to turn in the correct direction. Jerry
