5 members (37 GC, Dusty53, sron48, Vice-Grip, Otto Skorzeny), 130 guests, and 0 robots.
Topics128,114
Posts1,056,613
Members48,450
Hey guys, I can put my hands on a sweet running 250 with a two-speed powerglide from a 72 Pontiac Ventura. How hard would it be to put it in my 48 3/4 ton pickup? I have already updated the rear end to an open driveline. Any help/advice would be appreciated. Thanks, Scott.
Should not be real hard.
Engine and transmission cross members like what you would buy for a V-8 swap. Work out some throttle linkage, hook up some wire, and create a shift linkage.
Okay that's a little simpler than it would really be, but because it’s an inline not a V, you won't have the typical steering box interference problem associated with V-8 swaps.
You've already taken care of the rear end swap. This will still be a bit of work, but probably one of the easier swaps you could try.
