0 members (),
140
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 122 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 122 | What are the thoughts on brake light switches? As part of the front brake conversion to disc I am also going with a dual master and replacing all the lines, but I am not sure if I should go with a in line hydraulic or a mechinical one of some sort. I would need to find the switch locally so I am assuming NAPA or CarQuest or whatever may handle either type? Thanks! | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | The stock mechanical switch has always served me well. | | | | | Joined: Oct 2006 Posts: 122 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 122 | Ok, then that means that there is alreay a mechanical switch as part of the truck as built? | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | Here is one at Rock AutoAirtex part #1S5212 All of the vintage truck vendors have them also. They mount on the sloped portion of the floor on the firewall side with 2 small screws from the inside of the cab. The arm on the switch goes between the brake arm and the floor. | | | | | Joined: Apr 2009 Posts: 192 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 192 | Stock switch is the way, $ 13.00 and 15 minutes, from Classic Parts. Just changed mine, very straight forward. | | |
