0 members (),
172
Mod | | | Forums66 Topics128,196 Posts1,057,395 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#54632 01/07/2006 7:33 AM | Joined: Nov 2005 Posts: 144 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 144 | Can a 1987 chevy pick-up front suspension be bolted into a 1958 1/2 ton?
Is the track width correct?
Has anyone out there done this?
Thank you, Zeke | | |
#54633 01/07/2006 8:54 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Track width is about right, but the '87 and '58 frames are not very close to the same width. Where on an AD truck the width is only about half an inch off on each side, on the Task Force trucks its quite a bit different.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#54634 01/09/2006 9:03 PM | Joined: Nov 2005 Posts: 144 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 144 | Yeah, after further research, I've discovered that it's alot of work to do this. I found an article ove r at webrodder that shows this mod and it is not easy to do.
Looks like I'll be saving up for a fatman's m2 unit or staying stock.
zeke | | |
#54635 01/11/2006 5:26 AM | Joined: Aug 2005 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 51 | I know somebody that spliced a '78 chev front end to a '56 GMC and they said it wasn't easy, lots of work. An maybe a Camaro or volare front end would have been easier. | | |
