| | | Forums66 Topics128,139 Posts1,056,756 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | Went salvage yard shopping yesterday and came home with 3 carter yf carbs. 1-630 1-708 d1-788 Which one of these if any would be a good rebuilder for a stock 235 chevy. | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | My guess is that the numbers are from the throttle body.
If so, then 788 should fit your 235 manifold. The other two are probably too small and won't fit your manifold.
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | All three fit the manifold with the 708 and the 788 having a 1/8 inch bigger bore on the throttle body than the 630. | | |
