6 members (Otto Skorzeny, Bill Hanlon, Bisbee, 54farmtruck, dt235sd, klhansen), 103 guests, and 3 robots.
Topics128,148
Posts1,056,811
Members48,454
#546281 06/13/2009 12:38 PM
Went salvage yard shopping yesterday and came home with 3 carter yf carbs.
1-630
1-708
d1-788
Which one of these if any would be a good rebuilder for a stock 235 chevy.
My guess is that the numbers are from the throttle body.
If so, then 788 should fit your 235 manifold. The other two are probably too small and won't fit your manifold.
-Tom
1950 Chevy 3100 w/ 1956 235
All three fit the manifold with the 708 and the 788 having a 1/8 inch bigger bore on the throttle body than the 630.
