2 members (k2handyman, TooMany2count), 66 guests, and 2 robots.
Topics128,030
Posts1,055,418
Members48,422
What are the thoughts on brake light switches? As part of the front brake conversion to disc I am also going with a dual master and replacing all the lines, but I am not sure if I should go with a in line hydraulic or a mechinical one of some sort. I would need to find the switch locally so I am assuming NAPA or CarQuest or whatever may handle either type? Thanks!
The stock mechanical switch has always served me well.
Ok, then that means that there is alreay a mechanical switch as part of the truck as built?
Here is one at Rock Auto
Airtex part #1S5212
All of the vintage truck vendors have them also.
They mount on the sloped portion of the floor on the firewall side with 2 small screws from the inside of the cab. The arm on the switch goes between the brake arm and the floor.
RAK Offline
Stock switch is the way, $ 13.00 and 15 minutes, from Classic Parts. Just changed mine, very straight forward.
