1 members (78buckshot), 64 guests, and 3 robots.
Topics128,089
Posts1,056,004
Members48,430
#545982 06/12/2009 2:25 PM
mem
Offline
When i am bleeding the brakes can someone tell me what causes the fluid to come back out the master cylinder? i can't seem to get anything out of the top valve on the hydrovac. Can it be pressureizing itself inside the can?
3B Offline
Hy mem, a little geyser out of the master cylinder when bleeding the brakes is normal, it happens when the piston seal uncovers the compensating port, on it's way back to the at rest position. I would remove the upper bleed screw on the hydrovac, and make sure it is not plugged solid with dirt, hope that helps.
