4 members (farmallb, Peggy M, KingG, 1 invisible), 83 guests, and 4 robots.
Topics128,024
Posts1,055,393
Members48,422
#545862 06/12/2009 3:00 AM
k10
Offline
In my '61 I have a light bulb in the holder for the heater switches. It lights with the dash lights to provide illumination for those switches in the dark. I also have a single bulb which seems to go to the bottom of the dash above a hole in the bottom lip of the dash. It illuminates straight down to the floor. There is no holder for it, so I have some duct tape which doesn't hold the ground so well. The bulb is intended to light the floor hump for shifting, etc. Can someone explain what mechanism is necessary for the correct installation of that bulb ? Or even better, a picture of how it's supposed to be retained?
k10 #546195 06/13/2009 3:10 AM
Hmmm...my 61 does not have either of those lights...but mine is the cheap work truck model...so perhaps this is a premium trim upgrade that I do not have...
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
k10
Offline
Your heater levers should have a silver trapezoid behind the dash which holds the bulb.
Unless you have no heater, therefore no levers?
