7 members (48jim1ton, cmayna, HandyAndy, Gdads51, Otto Skorzeny, SmalltownTRKGuy, 52Carl),
90
0
Mod | | | Forums66 Topics128,050 Posts1,055,632 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 149 | I am planning on flipping the rear axle above the leafsprings on my 58 Apache. I noticed the Shock mounts on the rear are directly under the axle where leaf springs should go.
When I bolt the leaf assembly back together after the flip, will the rear shock mount go directly under the leaf? Or will it stay above the leaf, but below the axle?
I know tons of people have done this, but what about on a 58? | | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | well since i am currently playing with mine i believe that plate has to go below the axle when you put your ubolt through the plate is what you tighten the nuts too btw rat did you lower your front yet "please tell me your not doing a tail dragger" lol
1937 1/2 ton
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | "tons of people"?? he musta been quite large  real bad idea, the rear mounting was engineered as is for good reasons - you think the back yard engineers here know the safe geometry for your shock mounts? you trust those U bolts to take all the load of the rear of your truck, no matter what pot holes you hit? you going to cut the spring pads off and move them, subjecting the axle housing to that heat? you expect to get the pinion angle good enough to take your foot slipping off the clutch of the 350? considered what yer state DOT might think of it? if ya want it lower, do it right Bill | | | | | Joined: Jun 2009 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 149 | Lol, I haven't yet. But I will. I am working with Sid (SIDS drop axles) on getting a 4-6" front drop.
Danial, are you planning on a C-notch for your frame for your drop, and have you come across any complications flipping the axle? | | | | | Joined: Jun 2009 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 149 | Wait a minute Bill, slow down, you're making my head spin!
What exactly is the correct method to lowering the back?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | monoleaf ... fewer leafs ... bags ... frame mod [illegal many places] - anything except putting the axle up where the weight of the truck is all on the U bolts and the pinion angle is lost
when you've been here awhile you'll find this forum gives safety a pretty high priority
Bill | | | | | Joined: Jun 2009 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 149 | Safety is a definite priority. Even on my college budget, safety is still important. The problem is, those drop leaf springs are EXPENSIVE. Out of this world expensive. But Maybe I will consider removing a few leaf's from the spring. Would de-arching the springs also be an option? | | | | | Joined: May 2009 Posts: 6 New Guy | | New Guy Joined: May 2009 Posts: 6 | I would think that whatever you do to lower the rear, be it to move the axle over the leaf springs, remove springs, install different springs, your pinion angle will be off. The rear end ends up being closer to the frame anyway you lower your truck...just a thought. | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | stephen, i removed 4 or the original 7 leafs from my rear, and that dropped it 2 inches, then added shackele extensions and got another 1 inch drop, in the rear.
up front i also went with one os sids 3 inch axles, and took out 1 leaf, for right at 3 5/8 front drop.
leonard | | | | | Joined: Jun 2009 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 149 | Leonard, thanks for the tip! I may go that route.
| | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | I sure hope my 54 holds up with the axle on top of the springs. That sure is a lot of weight on those four u-bolts. Maybe I should change my 54 and put the spring on top of the axle like a TF truck. Oh, but wait a minute, it was designed that why and has held up quite well for over 50 years. In fact, those 55 year old bolts are in very good shape.
Sound fabrication practices and common sense will go along way towards a safe modification of the suspension of a truck or car. Where would the custom car and hot rod culture be if we lived in a society where we all had to drive a perfectly stock and unmodified vehicle. Pretty boring. | | | | | Joined: Jun 2009 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 149 | LOL, love the response. Finally, a true rodder in our midst! Last time I checked, the DOT was't even a word in a hot rodders vocabulary. I'm convinced, I'm flipping that thing tomorrow---
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | There's nothing unsafe about an axle above the springs. All the AD 1/2 tons came that way from the factory, as did countless other cars and trucks that had leaf spring rear ends. As far as putting heat on the housing, how the heck did the factory get those pads on there in the first place? Pinion angle is important as well as shock mounts and spring pads. The last TF I had I put a Firebird posi in (over the springs) and had the pads welded by a pro. I had that truck for many years and ran it empty and loaded with no problems whatsoever.
Flip away, be safe, be cool. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Flip away, be safe, be cool. Amen..........  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | ok i am confused most of the front axles i have seen have the bolt flange at the top how are you mounting it like that lol i need pics my 59 and 39 could both used a little lowerng
1937 1/2 ton
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | This thread is about rear axles. | | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | ahh ok  my bad
1937 1/2 ton
| | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | thought i had read another post by ratfink talking about the front spring flip
1937 1/2 ton
| | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | | | |
