6 members (Jon G, 68ironhead, 3B, DHedrick, Oswald, 1 invisible), 99 guests, and 3 robots.
Topics128,151
Posts1,057,009
Members48,460
#544666 06/08/2009 3:22 PM
Hello fellow stovebolters, on my 1950 3100
my fender to fender width, (ie; between the fenders where the grill assembly goes), seems like it is about 1 inch wider than my grill to fender mounting width. It looks like it is right around 48". I am assemling the frontend sheetmetal from scratch. Hood to cowl and hood to fender gaps seem good. Where did I go wrong? I havn't tried it but it seems like if I pull the fenders in that much I will screw everything else up.
Any suggetions?
Thanks for any help.
Roger
Start with the radiator frame and inner fenders- that is what determines the fender to fender spacing. Do you have an original or aftermarket grille? Is your grille assembled correctly? The bars are tapered.
Paint & Body Shop moderator
