| | | Forums66 Topics128,156 Posts1,056,870 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | You know, like the tractors. Is the stovebolt engine a structural component?
I pulled my old blown 235 (blew up, not supercharged)in my '52 GMC 3/4 ton and installed a 350 small block Chevy in it's place. Now mysteriously, my body panels are slightly out of place and I don't know how to adjust them back. It's almost like the frame is tweaked or the engine was holding the front in place. The hood doesn't close right, the front bumper is crooked, and when I look at old photos of when I first bought the truck, it's much straighter.
What the heck could have happened? If the engine was a structural member, then I can understand it. If so, how do I get my body back to straight?
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | no it's not structural, but the rad is, and any change in the rad support affects the whole front fit .... OTOH maybe you tweaked the frame when you installed the different mount arrangement, like a new crossmember welded in?
Bill | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | No, the engine just sits on the frame. | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | No, I didn't weld the V8 mounts in. They're bolted in. But I did remove the radiator because it leaked real bad and I replaced it. I can't see how that radiator is structural though. The radiator support and frame, yes, but a brass radiator? Well maybe that's a clue. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The radiator frame (radiator support) and how it is mounted is not a structural component in terms of structural strength. However, the mounting of the radiator frame can have an impact on the arrangement of body panels.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | in relation to the body structure, "radiator" is the assembly, not the fins n tubes - the core support is the front of the triangle that mounts and aligns the entire front .... tho that doesn't explain your bumper going limp, which could have a variety of unrelated causes, including something loose enough it 'just moved' .... did you take out the grill and remove the hood for the engine swap? .... have you inspected all the rubber involved, like under the core support and cab? considered weight change effect on the old front springs?
Bill | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | The 350 is a lighter engine than the 235, so there is less weight on the front springs rather than more. Perhaps that may have some effect on the panel triangulation? I don't know.
Yes I removed the grill, top of the radiator support, radiator and the hood and slid the new engine in right through the front. So it is conceivable that when I remounted those things, I changed things enough to where they didn't line up well. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | it's a sure bet you changed things just removing and reassembling - alignment of the front sheet metal requires a fair effort, not just bolting the right pieces in the right places, you'll find lots of threads here about the grief folks have had trying to get the front positioned well it's very common to find body shims on any old vehicle, required to get as close as possible to "right" - even changing the rotation of used rubber mounts can throw things out, an eighth inch tweak in one rad mount bolt can translate to a half inch extra gap at one back corner of the hood .... and maybe one bumper mount bolt was just loose enough that someone standing on the bumper shifted it a bit Bill | | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 | Anything mounted through rubber bushings is not going to transmit any significant force, unless bottomed out, so no.
Dave
| | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Wow, thanks guys. I'll check those links. I figured it was something I did different, but couldn't figure out what. I guess I know. I'll have to do some tinkering on the weekend and see if I can get it lined up better.
