9 members (Bizaircon, Youngin' Tut 59, klhansen, J Lucas, Hotrod Lincoln, 5 Window 9434, lumbersawyer, DougH6100, 1 invisible),
78
Mod | | | Forums66 Topics128,139 Posts1,056,762 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | Does anyone know if there's a reproduction clutch line available for the '60-62 trucks with the hydraulic clutch master cylinder?
It's got a flexible rubber segment in it that comes off the master cylinder and runs to the line, which is bolted to the engine and wraps over the bellhousing, down to the clutch slave.
-Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Nov 2008 Posts: 57 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 57 | Yes, there is. I just got a nice one about a month ago, and it was a vendor on the links page here. I will look for the invoice later today and confirm which one. -Ray | | | | | Joined: Nov 2008 Posts: 57 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 57 | www.GMCPauls.comLook in brake line section --Ray | | | | | Joined: Nov 2008 Posts: 57 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 57 | One more piece of info--GMCPauls is a retailer. The inside packing says the clutch line was made by a company called "inline tube." -Ray | | | | | Joined: Apr 2010 Posts: 436 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 436 | Thanks for the information in this thread. Inline Tube does indeed sell repo clutch hoses for the '62. I just ordered one today. http://www.inlinetube.com/62Stick 62 C10 Shortbed Stepside (currently) 63 C10 Longbed Fleetside (1977-1987) | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | I took a look on page 3 of the inline tube online catalog and did not see that line listed. Can you post the part number and maybe a copy of the catalog reference. It doesn't look as though you an copy and paste the catalog page directly. thanks. | | | | | Joined: Apr 2010 Posts: 436 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 436 | CTH6001 Hydraulic Clutch Line with stainless braided section Stainless $55.00 OEM $45.00
I hope this helps.
| | | | | Joined: Apr 2010 Posts: 436 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 436 | I just got the new clutchhose in from Inline Tube. Looks like the right hose.
K10, did the info I posted help you locate the hose?
