| | | Forums66 Topics128,193 Posts1,057,249 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | I've looked locally and can't find anyone who will make these hoses for me. I'm powering A Toyota Land Cruiser box with an old style chevy generator/power steering combo pump.
I can buy the hoses with one end correct from CPP(the toyota side). It has chevy pump fittings on the other side which I'm told are not the same as what I have(55-59).
Anyone know of an online source that could take the available CPP hoses and put fittings on the pump side of the hose that will work with my old style 55-59 chevy pump? Application is a 55, 2nd series.
Thanks in advance,
Keith | | | | | Joined: Aug 2006 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 84 | Have you tried going to a hydraulic shop.. More time than not they make custom length hoses, press on fittings, the whole 9 yards. That would be my best guess. | | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | From what i remember bout that artical that someone did he used a later metric power steering pump and the gm metric hoses, if i am wrong someone plz correct me
1937 1/2 ton
| | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | btw hope you keep the steering conversion on your photo bucket  i am thinking of doing the same conversion "pictures are worth a thousand words"
1937 1/2 ton
| | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | ya- a number of people have asked about a photo session..a good time to do it..no fenders, hood etc. It will be a combination of Toyota power steering/dropped axle/Tilt steering column..I've had this truck about 30 years and have dreamed about power steering the whole time..partially due to the fact one king pin won't take grease..lol. Of those I've chatted with that have made the conversion...they love the results. Using the old generator power steering combo is my twist on the scheme...saves having to make a pump bracket and I believe the pump output is better matched for the Toyota box...otherwise you'll likely need to step the output down.
Keith
| | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | where are you getting the dropped axle from and whats that setting you back "price" lol would love a link to it if you have one
1937 1/2 ton
| | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | oh that reminds me "concerning your toyota queston" i remember the artical i read mentioning a pressure regulator on the setup some place toyota puts out a higher pressure than the gm pumps which could blow seals if you don't decrease that
1937 1/2 ton
| | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | err might have been the other way around i mean lol gm puts out more than the toyota pump
1937 1/2 ton
| | | | | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | Most NAPA's can make the hoses up from scratch.
'67 GMC 3/4 292 4spd
| | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | Really Napa? We have one out here..I'll check it out
TX | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | for hoses look under hydraulics, power transmission and bearings(a lot of times these go together). isf you can find someone who handles Aero-quip fittings and hose they should be able to fix you up. Also major truck shops and heavy duty equipment ron | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Just a suggestion...if you have the Toyota hi-pressure line and it's long enough to mate up with the GM pump......just grind off the end of the flare to the pump.....use a GM fitting (which you'll have to file out the inside diameter just a hair) and make a new flare.
I've done this on a couple Toyo conversions with no problems. Of course, you've got to have the long enough Toyo Hi-pressure hose to make this work. A flare is a flare and the Toyo steel line end will take a standard flare and the GM fitting will assure a leak-free fit.
Dave | | | | | Joined: May 2002 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: May 2002 Posts: 30 | Hi All, Can someone please post a link to the aforementioned article concerning the Toyota steering box swap? TIA Gene
horseballz =========== '56 Chevy 3200 '69 Ford F250 '68 Mustang Coupe/5.0 Roller/T5/Factory A/C '03 Miata (Wifes Ride)
