3 members (tclederman, Guitplayer, 1 invisible),
49
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,154 Posts1,056,853 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 111 | The kit comes with 3 bumpers per door. I have the hole in the post at the top and believe the larger thimble shaped bumper should go there, however new panels were put into the bottom and no holes exist. Were did the smaller thimble shape bumper and the flat circular bumper go. Any help appreciated | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The other 2 bumpers go in the cab. One at the top rear corner, the other at the lower rear corner. I'm thinking the 2 thimble shaped bumpers are the 2 that actually go in the cab, the flat one goes in the door itself.
Bill Burmeister | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | bigger thimble top of rear post, smaller bottom of rear post - about the same distance from the bottom as the top one is from the top .... flat one on the leading edge of the door just above center of the vent window, should be a hole there
Bill | | | | | Joined: Oct 2006 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 111 | Thank you guy,s for the quick reply. | | |
