1 members (UtahYork),
80
Mod | | | Forums66 Topics128,049 Posts1,055,637 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Hey Bolters! The engine in my 56 3100 is getting tired and my ace mechanic told me to shop for a new short block. I have what I believe to be is a 59-60 engine - Block #3769716, Stamped ID F0301BE
Any idea on where I can buy a rebuilt short block?
Thanks!
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I would say You should shop around for a good rebuilding shop in Your area , I am lucky that I live close to Chicago and have many good shops , I do My own work and just farm out the machining it is not as hard as You might think as long as You follow and read the instuctions , there are many good books to help You along the way and of coarse the bolters will help.If You can take it apart You can take the short block to a shop and have it redone than You will know that Your engine is going to give You good service for many years .
Pete | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Find a solid engine and have your mechanic rebuild it. That way if something goes wrong, you're covered... or at least you should be if your mechanic is a stand-up guy. | | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | You might consider Jasper or one of the other reputable rebuild shops. If they have a participating dealer/ store near you they cover the freight. http://www.jasperengines.com/gas-engines.phpTry the swap meet section on this site or on inliners.org. Of course 235's show up on eBay regularly... Good luck.
Professional Novice
| | | | | Joined: Oct 2008 Posts: 26 Apprentice | | Apprentice Joined: Oct 2008 Posts: 26 | | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Thanks for the leads! Any others?? | | | | | Joined: Sep 2001 Posts: 272 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 272 | check the links swapmeet here I see 235's all the time some for free, Brad | | |
