| | | Forums66 Topics128,196 Posts1,057,391 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#54414 01/03/2006 11:48 PM | Joined: Jul 2005 Posts: 32 New Guy | | New Guy Joined: Jul 2005 Posts: 32 | This is installed on my 54 chevy. It had a v8 conversion done by the previous owner and i'm trying to figure out what type of differential this is. Thanks! The images are on my site: http://homepage.mac.com/spider/PhotoAlbum21.html I removed the pics that were here before to limit bandwidth usage. | | |
#54415 01/04/2006 12:02 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | welcome to the garage volcan - preference here is to use the link for the pics rather than putting them directly inline - saves on the transfer bills for the owners looks like possibly a mid 50's car rear to me, like 55-57 sedan, which in the past was a common swap to get 5 bolt wheels, if that's what's on it Bill | | |
#54416 01/04/2006 12:22 AM | Joined: Jul 2005 Posts: 32 New Guy | | New Guy Joined: Jul 2005 Posts: 32 | Thanks for the info! I suspect that the v8 is also from aorund the same time frame, but I haven't gotten around to looking into that.
Also, I edited the post to remove the pics.
volcan96 | | |
#54417 01/04/2006 12:38 AM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I cannot be sure but it looks like the rear in my tri-five Chevy so my guess is from 55-59' car. | | |
#54418 01/04/2006 12:46 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 |  good on ya! actually more than 'bandwidth' it's 'bytes transferred', kinda like a mileage charge yes moneypit, I too thought it looked like tri5 cars I've had, and also the 57 rear that was under my panel project when I got it - that swap had been done 20 or more years ago Bill | | |
#54419 01/05/2006 2:03 AM | Joined: Jul 2005 Posts: 32 New Guy | | New Guy Joined: Jul 2005 Posts: 32 | Guys,
Thanks for the information! | | |
#54420 01/05/2006 4:30 AM | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Who gets "charged" for bytes transferred if the bytes transfer from my photo server to the viewer's browser? I understand how The Stovebolt page might be charged for bytes-transferred by images hosted on the Stovebolt Page webserver.
On the other hand, displaying pictures (rather than links to pictures) that are hosted on a non-Stovebolt Page server would be an inconvenience to a person using a dial-up connection (they would only want to spend timing loading images of interest).
It seems to me that Stovebolt Page server bandwidth and/or bytes transferred (by the Stovebolt Page server) are not impacted by photos hosted on a poster's server (and served directly from the poster's server to the viewer).
If I am wrong about this, would someone explain how a photo hosted from my server would produce a charge (transfer bill) to anyone but me (it is quite possible that I have totally incorrect/confused understanding of this concept).
Either way, Red58 is correct that the etiquette on this forum is to post links to images rather than using the UBB "IMAGE" (display hosted image) option. We should all follow the site-etiquette. | | |
#54421 01/05/2006 5:10 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | it is confusion making - some charge is on the site that serves the pic, as well as the site that hosts it - if the pic is hosted away from here, it still hasta be 'commanded to appear' by the bolt server if it is directly inline, and with the asp or whatever setup is used, the bolt server has to integrate it into the page served to the viewer, somehow, even if only supplying the extra lines in the scripting here, so there appears to be some additional 'byte load' added to the bolt
charges are for amount of bandwidth allotted as well as number of bytes transfered - however it works, Peg did say once that they learned the hard way that inserting inline pics gets more expensive fast!
Bill | | |
#54422 01/06/2006 12:47 AM | Joined: May 2003 Posts: 224 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 224 | could that be the original rearend? didnt they switch to open drive shafts in 54? or was it mid 55? | | |
#54423 01/06/2006 2:11 AM | Joined: Jul 2005 Posts: 32 New Guy | | New Guy Joined: Jul 2005 Posts: 32 | I'm pretty sure that open drive lines came with the TF 55 model and that the 54 and 55.1 had the older driveline (at least that's what the 54 shop manual that I have shows) | | |
#54424 01/06/2006 2:49 AM | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | volcan96,
You are correct about 1954 1/2 tons having an enclosed driveshaft but the 1955-1st series 1/2 tons had open driveshafts.
Tim | | |
#54425 01/07/2006 6:46 AM | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | I have two of these rear ends in my 1932 Chevy's, I just looked at them and that is what you have, 1955 to 1957 passenger car. They work good, will stand quite a bit of horsepower and are the right width for the '54. The same housings were used in Corvettes of that vintage, and I have a center section from a '59 Vette in my '32 pickup. It is a little beefier that the pass. car one, but bolts up the same. They have a great range of gears too, from 6.17 down to 3.08 | | |
