1 members (Bucker),
144
Mod | | | Forums66 Topics128,196 Posts1,057,391 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#54353 01/03/2006 1:43 AM | Joined: Jul 2005 Posts: 11 Junior Member | | Junior Member Joined: Jul 2005 Posts: 11 | Wow I have work on a lot of my own junk, but I can't find the bellhousing bolts to pull my engine. It is a 49 chevy 3600 with a 216 engine and 4speed trans. I pressure washed the oil away, maybe I can find them when the ground dries. If anyone has a photo of a 4 speed trans bellhousing, please forward them. Thanks Greg | | |
#54354 01/03/2006 2:00 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The bellhousing bolts are under your flywheel. You can leave the 4 speed in the truck and pull the engine with bell housing attached. You'll need to pull the radiator & frame. And you'll need a timber or a pipe laying across the floorboard and a tiedown strap to hold the tranny up. | | |
#54355 01/03/2006 2:13 AM | Joined: Jul 2005 Posts: 11 Junior Member | | Junior Member Joined: Jul 2005 Posts: 11 | Cletis, you tha man. When you said pull the frame, did you mean the front of the truck (grille area)? My Dad gave me his 3600 before he past, and I am gradually working on it. I believe it was a comercial truck. | | |
#54356 01/03/2006 2:41 AM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | you must take the pressure plate and flywhheel off . There are four bolts, two on each side. Take the little inspection plate off the bellhousing,you will see them . 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
